I'm working on resurrecting a top hat ball bowler and almost have it fully working. I've just got a few little issues I'm trying to work thru that I need help with.
The beer frame game isn't working correctly. I have a copy of the schematics but they do not show the logic for the beer frame feature so I'm not sure how to troubleshoot it. I can manually operate the relay and the beer frame light will light on the backglass but it will not operate on it's own. I've tried changing the setting on the jones plug from mystery to 5th frame and it has no impact other than when it's on mystery the flash o matic motor does run. Any suggestions would be helpful.
Next issue I have is on the step up game it does not score correctly. The first two options work, I'm not sure of the exact values but lets say for a strike it's 30, 60, 90. When 30 is lit a strike will give the correct points, also 60 will work correctly, when the light cycles to 90 it still gives 60 points though.
Also the Red pin feature scores 50 points for every strike, not just when it's supposed to.
I'm not sure how the scoring logic works on these games so I'm at a bit of a loss.
