I'm not sure what your definition of "restore" is, but I'd just get it working and clean it up as best you could. I wouldn't clear the playfield or repaint the cabinet.
Doesn't work may mean bad fuse or no credits on the machine, who knows. I've never run across an EM that I couldn't get to work (as long as everything is there).
As far as getting the game going, it has all the same things inside that all EMs have...steppers, relays, score reels, score motors, etc. The game specific parts are going to be harder to find than a Willams, Bally or Gottlieb. Fortunately most of the time you don't need any specific parts. Generally cleaning and adjusting contacts is all that's needed. Parts like new rubber rings and bulbs is all you may need to have as far as parts are concerned.
Now, I only have one CC pinball game and I will tell you that the score reels are about the finickiest things I've ever worked on. They are super simple in design, but so hard to get to work right. They used a printed circuit board with traces that several wiper fingers ride along. The problem is the wipers put too much drag on the entire score reel. You have to make sure the traces are clean, lightly lubed and that the wipers have the right amount of tension on them. Too much tension and the score reel doesn't move correctly. Too little tension and it wont zero out when resetting or advance the next score reel when it reaches 0. So be prepared to spend time cleaning and adjusting them quite a few times.
