NOTE: TO ANYONE HAVING TROUBLE VIEWING THE UPLOADED SCHEMATIC, HOVER OVER THE THUMBNAIL THEN CLICK THE DOUBLE HEADED ARROW IN THE BOTTOM LEFT CORNER. GIVE IT A FEW SECONDS TO RENDER CORRECTLY. IT MOVES SLOWLY. NOT SURE WHY BUT THIS SEEMS TO BE THE ONLY WAY IT WILL DISPLAY WITHOUT BEING TOO BLURRY TO READ.
Recently picked up a "Pinball by Stern" from 1977. Marked as a Stern but internally, it's a Chicago Coin. I'm having an issue where I turn it on, press credit button, score reels reset (most do, I have to reset 2 of them by hand), but the score motor keeps turning and the reset relays keep hammering away. I have cleaned and rebuilt all score reels. I have verified that every one has continuity on the zero position (even the two I have to reset by hand) as Chicago Coin's don't use an EOS switch. While everything is trying to reset I can manually activate the Reset Relay and everything stops and it kicks a ball out and plays like normal all the way through a game. Well, mostly normal. I do have another issue that I'm not sure is related to the reset issue. I'll list it here just in case. During gameplay the machine will end the game after 4 balls. It skips the 5th ball and goes right to Game Over. It does the same when set to 3 balls. It skips the 3rd ball and goes to Game Over. But if I manually activate the Ball Count Unit it goes through all 5 balls lighting the appropriate lights on the back box as it goes. There are one or two other small issues relating to bonus lights and things like that but I don't believe those are related to my reset issue.
So far I've cleaned and rebuilt all score reels and verified their continuity in zero position. I've cleaned and put light coat of super lube on all stepper units and verified that they all work by manually activating them and watching the appropriate lights change. I've cleaned switches on all of the relays relevant to the reset/start up process (at least those that I've been able to identify with the schematic.) Also cleaned several score motor switches relevant to this process. I would note that one of the related score motor switches produces a large blue spark when activated. This occured before and after cleaning. Not sure if that is indicative of a problem but it's the only motor switch that does this. I believe it was the A1-3 or A1-4 switch. Not sure at the moment and I'm not in front of the machine. Checked all fuses and verified continuity and appropriate amperage ratings.
So, any suggestions as to what I can try next or something I overlooked? I've attached the continuous schematic. I'm relatively new to this. I purchased my first EM a few months ago. I was able to learn the schematics and eventually got that one fixed and working 100%. This one is proving to be a little more difficult though. Lol
