I have the same issue on a Chicago Coin Red Baron and a Stern Stampede. Since these are basically the same manufacturer maybe it is the same issue on both. The issue is when it hits the lower kickers it doesn't score. It does kick the ball as it should. On the Red Baron the upper contacts behind the o-rings will not score either but the ones midway down the playfield do score. Thank you in advance for helping.
