(Topic ID: 285263)
Chicago Coin mustang EM Project Help
By Enron64
1 year ago
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by HowardR
#1 1 year ago
Hello All,
This is my very first EM and is a project pin. I have been going through the machine cleaning and fixing issues as they come up. I have cleaned all the plug connectors, checked the fuses, a scoring switch on the playfield was stuck closed so I adjusted that. The coil on the scoring reel for 0-9 was burnt out probably from that stuck switch on the playfield, so I replaced that. So here’s where I am at. The game turns on and I get lights. I push the game start button and the score motor turns and starts up at ball 1. I have no flipper power, pop bumpers, or any of the scoring switches except 2 30 points switches have power. However when I press either of those switches the score motor will turn but the score reels will not turn at all. Also if I let the balls just go through the out hole it correctly moves on to the next ball in play and will go through all 5 balls and end a game and show game over. Any help would be greatly appreciated. Thanks
#2 1 year ago
Here are the circuit and the 4 switches that control power to the flippers.
Inspect and diagnose this circuit with Alligator clip jumper wires
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
Example of a pinsider actually doing this https://pinside.com/pinball/forum/topic/red-baron-tech-question#post-5858156
#3 1 year ago
Thank you very much. Some of the wires on that schematic aren’t matching what I have. I can confirm that start relay fires and activates a game. I can confirm the game over relay fires and ends the game. I can confirm the out hole relay fires every time a ball is drained. The tilt relay is not working as I have manually activated the relay and nothing happens. I also tried and activated it via the tilt bob and nothing either. It seems to have no power to it.
#4 1 year ago
Quoted from HowardR:
#5 1 year ago
If you'd like to try a phone call, send me your cellphone number in a private message and I'll make a first reply with a text message.
#6 1 year ago
The problem turned out to be the switch on the #2 Start relay not making a good connection.
BTW, Mustang has an inaccuracy on the schematic. The Coil legend at the bottom left lists a #1 Start relay and a #2 Start relay, which is correct, but the problem switch is shown merely on the Start relay. See the schematic fragment in my post above:
https://pinside.com/pinball/forum/topic/chicago-coin-mustang-em-project-help#post-6058149
