I have a chicago coin jukebox that I've been working on .got all the score reels to reset to zero ,cleaned all the circuit boards and the wiper blades on the score reels
but when credit button is pushed the reels all reset but the score motor keeps running.im working on replacing the wire harness connectors that slide on the score reels circuit boards as some are cracked and wjen I wiggled a few of them the problem.stopped .I replaced these and the problem now continues.
then I thought I had it solved when I slightly moved another score reel,the zero wasnt quite "locked "in on the reel .id move it a little and the problem stopped .cleaned and fixed this score reel and the problem of constant running score motor continues
if I manually release the start relay I can play a game ,i can play a single player or multiplayer depending on number of players I select .
any other ideas or just keep replacing those wiring plugs to the score reels
Thanks for all the help
