Have a Chicago Coin Hollywood (2nd one actually) that upon turning on the machine is firing the S and A kick out holes (actuated by same coil). The S relay constantly activates but not the A relay (only one has to pull to activate the S and A kickouts because they are actuated by the same coil). The only way I can get S relay to stop firing is put paper in between normally closed motor switch 3A. Well then none of the kickouts work because 3A needs to close to activate the kickouts. 3A opens and closes fine. Have tried adjusting it to both extremes. S hole switch is not stuck closed. All S relay switches are normally open and open and close just fine. Ideas?
