Hello Pinside.
Have a hollywood that will not properly reset. It's acting like there is a ball in the "t" and "r" hole and keeps trying to eject the ball from there.
• Check the spacing on the switch for both holes. Perfectly adjusted
• Coin door has a small relay on it that keeps looping on off when machine powers on.
• Lock relay is energized when machine powers on otherwise open as expected.
• Machine can score and goes through balls accurately when a credit is added.
What else could be causing the "t" and "r" relay to fire and keep the score motor running. Looked at all switches on the score motor, and from the map on the side (Thanks CC!~) it's perfect. It was working fine for about a month and then had 29 or so games on it and it stopped. Thinking it might be coin door, but welcome thoughts.
Could be that the table doesn’t think it’s compleated a reset properly.
