Hi
I am currently restoring a number of pinball machines and I am stuck on an issue with a Chicago Coin Hollywood Machine. I have replaced several solenoids that were faulty and we have finally applied power to the machine. The issue we are having is as soon as power is applied to the machine the Cam runs constantly and activates all the solenoids on the playfeild and does not stop. Have you any suggestions as what can be causing this.
Also it seems to be the cam sometimes continues to run but only activates the Score Reset Relay. The scores are set to Zero but it continues to run.
Donovan
