Quoted from Kickout:Picked up a Chicago Coin Hee Haw. Have credits. score reels zero'd, push start nothing. Manually push game reset relay, game starts but score motor continues to run, Ball count unit continues to run. 1st and 3rd Player score reset relay continues to fire. Any ideas or suggestions on where to start?
Kickout
Sounds like you may have a score reel or 2 (or more) that while showing zero in the display is not actually at the zero position with regards to the switch on the reel. I would remove each reel and actuate by hand to make sure the switch is making and breaking when it should. If it appears to be then it may just be a very dirty switch that needs a flex stone cleaning. Grab a score reel that is already working correctly and watch how it actuates the switch on the score reel when in position 1-8, 9, and zero.
I will add Chicago Coin score reels are notoriously finicky...I have had 2 Hollywoods.
