(Topic ID: 302578)
Chicago Coin - Gun Smoke - Score Motor testing
By smohr
2 years ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by Mopar
#1 2 years ago
Hi,
I just got a CC Gun Smoke (project), I dont know the history. Before I powered this up, I did the following..
Checked all switches they appear to make/break, open and close when manually activated.
Checked/cleaned all score reels they advance snappy.
Checked/cleaned all steppers they advance and/or reset snappy.
I turn the power on I get nothing
I hit the left flipper and I get GI lighting
I have credits on the credit wheel, I press the start button on the coin door... nothing happens
I manually rotate the score motor cam (slowly) and the scores on the back box start to reset to zero but have to do it manually
Could the score motor be bad since it's not rotating at all, how can I tell if the score motor is good/bad.
Im not familiar with the actual start up steps.
Any thoughts/suggestion?
Thank You
Steve
#2 2 years ago
That's what's nice about a vari-ac. You're able to try out light sockets, coils, and motors without
the machine even plugged in..
Anyways, with a volt meter, you can check if the motor is getting any juice, but 10 to 1 it isn't.
Because the lights comes on tells us that the 110 and 6 volt fuses and fuse holders are okay, but
did you happen to check the fuse and its holder for the 30 volt circuit?
#3 2 years ago
Thanks Mopar,
I did check that and it's OK... I snooped around the score motor checking the wiring to/from the motor, guess what I found.... hidden... a slide on/off switch. so I jumped around that switch and now I do get motor activity (Yeah), just spinning, non-stop. So progress is being made. Now I just need to find out why it's doing that. I'll mark this as solved.
Steve
#4 2 years ago
I have a Gun Smoke, but I haven't gone through it yet or any other C.C. from that era in quite some time,
but if the score reels are resetting to zero, I'd check their contacts and also the contacts on the bonus unit
but because that machine has a flash for bonus, I'm thinking it probably wouldn't have run-out contacts..
This page was printed from https://pinside.com/pinball/forum/topic/chicago-coin-gun-smoke-score-motor-testing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
