New! Dark mode!
(Topic ID: 49051)
chicago coin dolphin flipper issue
By pops21
7 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 7 years ago by pops21
#1 7 years ago
I just got a project chicago coin dolphin game. It sat for about 20 years. We got it working great played it but left flipper was weak and out of alinement . we adjusted it and cleaned fingers. It work perfect for aminute then became unresponsive. I lifted playfield and coil was extremely hot. If I manually moved flipper it would move but extremely weakand bearly on its own. Is it the coil gone bad? Is it something else?
thanks
#2 7 years ago
If the plunger is sticking in the coil, the coil is shot. And you need to get the EOS points working right so you don't destroy another coil.
#3 7 years ago
the other flipper has no markings. this damaged coil says fl21-375 (williams model) the book calls for a fj29400/21-375. is it the same?
#4 7 years ago
WLL-FL21-375 - Coil FL21-375/28-400 <-Williams coil listing From PBR http://www.pbresource.com/coilwms.html
It is the same gauge and turns as the Oem ccm. (substitute)
Flipper coils usually have two sets of part numbers (Ex. 21-550/26-1200, EOS flipper wiring) because they have two coil windings on the same solenoid coil body. The first set of part numbers (21-550 in example) indicate the strength of the flipper (pull in coil used to raise the flipper). The last set of (26-1200) indicate the coil strength used to hold the flipper fully upright (solenoid core hold in coil).
The number of wire turns on the second set of the flipper coil part number is always larger then the first number of wire turns because the coil does not need to be strong when holding the flipper upright. The flipper coil "hold" coil does have to be able to be activated permanently without burning up the coil. This is why a lot of turns of wire are used on the "hold upright" coil on a flipper coil. ^ Via Pinball medic^
http://www.pinballmedic.net/images/parts/eos_flipper.jpg
#5 7 years ago
thanks for your help
$ 2.50
Doc's Pinball Shop
Metal-Mods
$ 69.99
Filament Printing
Displays
PinballSolutions.eu
$ 7,299.00
Classic Game Rooms
$ 9.99
$ 7,599.00
Great American Pinball
$ 45.00
Playfield - Plastics
Ramp-O-Matic
$ 14.95
$ 9.99
Bent Mods
$ 32.25
The MOD Couple
$ 5,899.00
Classic Game Rooms
$ 29.99
Lee's Parts
$ 7,599.00
Little Shop Of Games
$ 29.99
$ 76.95
$ 64.99
$ 95.00
pinballmod
$ 7.00
Medisinyl Mods
$ 24.95
pinballmod
$ 209.99
$ 52.00
Pin Monk
