(Topic ID: 298981)
Chicago Coin CINEMA need help
By crassmage
9 months ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 8 months ago by PinballAir
#1 9 months ago
Im posting this for a friend who bought a CC cinema. Apparently they brought it home played maybe 10-12 games and on completion of the last ball for the last player (3players i believe). The game has since been stone dead. I wasnt there but they said there was no sounds or smells(burning) from machine. EMs are not my forte so looking for advice as the where to begin. I have already checked all the fuses i could find for voltage and continuity. Thats it other than plug into other outlets etc
Thank you for any helpful ideas.
#2 9 months ago
If the Lock relay doesn't activate when you push the Left flipper button, try activating it manually.
#3 9 months ago
is it reset and dead, or still showing scores from last game?
#4 8 months ago
Quoted from HowardR:
Will give it a try, thanks
Quoted from PinballAir:
I will check today.
#5 8 months ago
Based on the pic i took the 3 scores are still there yes
Yes, confirmed, the scores are still there on 3 player reels
#6 8 months ago
Still darkness.
#7 8 months ago
Have you ruled out the line cord and plug? Voltage tests at the transformer would be next.
#8 8 months ago
Do you own and know how to use a multimeter?
#9 8 months ago
So after probing around i found it. Checked voltages on the fuses and the 10amp fuse that goes to the on /off switch had a wire that had fallen off. It hid itself very well as it is black and the bottom of the cab is nice and dirty. Also it tested straight across the fuse with voltage so Just assumed it was good. Sometimes its the simple stuff.
#10 8 months ago
Nice!
Play ball!
Twisted Tokens
$ 45.00
The Flipper Room
