This Cinema is the first pinball that I ever owned... now I'm at 9 EM's. I've had this for 5 years or so and it's run fine up until recently. All it needed when I bought it was a new ball, rubbers and a play field waxing.
So, today I'm trying to figure out why it goes into "end of game" at 2 balls instead of 3 or 4 balls when it's set for 5 balls.
The ball count stepper switch seems to be functioning fine, it steps up and it resets back to the "factory position... indicated by orange paint on the circuit board and contact finger" first position okay. I have had the stepper switch disassembled for cleaning but I'm about 99% sure that it is reassembled properly.
When I get a new EM, I will always totally go through them, play field, cabinet board and score reel board. I disassemble and clean all stepper switchs, score reels, score motor, all switches, relays, wire solder joints etc etc. I've had great success in doing this and it virtually always fixes anything that's wrong. So, this isn't my first rodeo.
That said, I did totally go through this Cinema since it was starting to give me grief. The score motor was running continuously, I tracked the problem down to an internally broken wire in the score reel "0" circuit. On a 4-player game it was occasionally scoring points for a different player but that's no longer an issue.
So, now I have this 3-ball, 5-ball problem and I'm guessing that it's something that I screwed up since this wasn't a problem before
Any help would be much appreciated.
Thanks,
John
