Started working on the Chicago coin Bullseye baseball that I picked up in the Tulsa auction- all steppers ( save the credit stepper) have been cleaned and are no longer sluggish, plugs replaced and or cleaned, and playfield dust and grime removed. Now I'm working on getting a game started- credits manually added to the stepper and I hit the button on the coin door- all credits zip down to zero- not stepping down but the reel freewheels down to 0-
I thought id was a jammed up arm/ spring assembly. Adding credits is easy by depressing the coil-same with removing credits- the coil at the top, even if i try- won't allow more than one credit to be removed per coil movement. am I missing something? I will pull the credit unit out and clean like the other- and maybe that will do the trick- I just thought it was physically impossible to have more than one credit tick down as the coil is energized....
