(Topic ID: 259015)
Chicago coin bronco blowing line fuse
By the96stang
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by HowardR
#1 4 years ago
Anyone have any idea why an EM would blow a line fuse? I have continuity between both points that the line cord is supposed to be soldered to. The line cord has already been removed and the play field and back box are unplugged.
Do I have a bad transformer?
#2 4 years ago
While you're figuring it out, make one of these Fuse circuit breaker
http://www.pinwiki.com/wiki/index.php?title=EM_Repair#Electrical_short_troubleshooting_Fuse_helper
#3 4 years ago
Got one.
How do I narrow this down.
#4 4 years ago
Your transformer could have a short. Try unsoldering the secondary (Low Voltage) wiring and see if it blows the line fuse. If it does with nothing connected to the output, you will need to replace the transformer.
#5 4 years ago
Quoted from the96stang:
Chances of having a bad transformer is very slim.
Is this a machine that you just start working on?
Do all the coils work freely and not look burnt?
Wouldn't think its the score motor windings..
You can unplug the head and playfield. If it still
blows, you know it has to be in the lower cab.
#6 4 years ago
Quoted from Mopar:
Everything is unplugged minus the bottom board of the cabinet.
When I disconnect the LOW line and test right on the transformer I have continuity between the high and low windings on the transformer. I am assuming I should not.
Also, with that one lug disconnected on the transformer all of the coils now have the appropriate resistance.
#7 4 years ago
If all else fails, you can disconnect all the transformer wires, and hook up the input through a fuse. If that fuse blows with power you have a bad transformer.
This page was printed from https://pinside.com/pinball/forum/topic/chicago-coin-bronco-blowing-line-fuse- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
