Is there anyone who has actually received some help from Chicago Gaming recently?
We bought a Cactus Canyon around October of last year and...to put it nicely...it's been a nightmare machine. Out of the box it had random switch issues that would randomly just go nuts and blow up the player's scores without the ball actually hitting anything. Usually an employee would power cycle the machine and that would clear it up and then when I would try to troubleshoot it, I'd find a random switch that possibly just needed a little tweak.
So I just thought some of the switches were a little too tight from the factory and as the machine got some play they just needed some adjustments.
But the reports of ongoing random switch issues continued.
Then the first "Bad Guy" drop target locked up it's little coil that knocked the target back down and it blew the fuse under the playfield. I contact CGC, I'm told our machine was the first to have this issue and they sent me a new drop target mech and I sent the old one back for them to look at it.
And just about a month or so passes and as I'm trying to diagnose more reports of switch issues/scores just blowing up on it's own and I find the same drop target coil on the new mech has also locked up and the playfield fuse has blown again.
I put another ticket in and I get a couple of troubleshooting tips from a tech who is also a member here, but the machine has pretty much descended an unplayable mess as the wild switch issue has become more consistent.
I run down each switch that seems to randomly "machine gun" faster than humanly possible and eventually I think I have narrowed it down to the network cable that connects to the main board under the playfield. If I wiggle that cable at that connection, I can get the switch issue to start and stop. Unfortunately, if I get it to where the issue stops, shortly after I close the machine back up it just starts all over again.
I've attached a gif shows the score blowing up, but the ball isn't moving at all.
This video shows a random switch that was machine gunning, but if I triggered the switch manually, it would stop until I let go of the switch and then it went right back to machine gunning. https://imgur.com/a/TpKOJWd
I've even had multiple switches machine gun at the same time! https://imgur.com/uA2vd3g
