Hi,
I changed the bridge rectifiers and a few minutes it was OK, and then began to throw balls and reappeared error "check fuses 114 & 115".
There is no voltage on the F115, LED 1 does not light up.
Fuses and bridge rectifiers new.
Hi,
Quoted from fly:There is no voltage on the F115, LED 1 does not light up.
If your new fuse still tests good, measure the voltage at TP7. It should be at least 12.5VDC. If not, check to make sure you didn't damage a trace from the BR5 to the C30. Add a jumper as needed.
Quoted from fly:TP7 - 23,9
23.9V or 23.9mV ? I never seen/heard a voltage higher than 18v at TP7.
Quoted from PinballManiac40:23.9V or 23.9mV ? I never seen/heard a voltage higher than 18v at TP7.
23,9V
Quoted from fly:23,9V
By your response, you must live in the eastern hemisphere. That voltage is too high. I am wondering if your transformer is wired correctly.
Need more history on your game. How long has the game been working before the F115 blew? Is the game a 220v machine and you have that coming out of the wall socket?
This page was printed from https://pinside.com/pinball/forum/topic/chek-fuses-114-115-no-voltage-on-f115-dirty-harry and we tried optimising it for printing. Some page elements may have been deliberately hidden.
