On a computer board with an AC test point, where do you put the other lead of the DMM? Since AC doesn't use ground I wouldn't ground it. Do I just find a connector pin that is the AC return line? For example the rectifier board on early Bally's have TP4 which is 7.3 VAC. I would put one lead on TP4 but where would I put the other lead?
Thanks.
