New! Dark mode!
(Topic ID: 2610)
check your WH2O's (G.I. related)
By NoVArcade
9 years ago
  • 14 posts
  • 13 Pinsiders participating
  • Latest reply 8 years ago by PinballHelp
#1 9 years ago
judremy, this might have been the culprit to your blown fuse. I've been chasing an intermittent high resistence reading to ground on the upper playfield GI circuit. I believe I've found the culprit, the fix was easy, but the location of this socket boggles my mind. There should have been a service bulletin for this. Put a piece of tape on the backside of the socket that might come in contact with the left side rail.
#2 9 years ago
I remember that spot well now that I see it. Had a GI short that I traced there as well on my White Water
#3 9 years ago
That wasn't the problem on mine. On mine it was the tab being bent in too far making contact with the mount (if that makes sense) on a backfield GI or two. I will definitely check on this tomorrow!
In other news, my friend and I just spent the last 10 hours doing a "quickie" shop job on WH2O. You can see some pics at this link:
https://picasaweb.google.com/judremy/Pinball#
My wife repainted Bigfoot too and he looks great. Please let me know what you think!
#4 9 years ago
Just an FYI... I did go and put electrical tape in those areas. Mine weren't touching, but dang was it close.
#5 9 years ago
Nice find, makes me want to look under my machines playfields and look, just incase there is something simular.
Looks awesome and Bigfoot looks GREAT!
#6 9 years ago
Nice tip NoVArcade. Thanks for sharing with the rest of us. I don't have enought hair left to be pulling it out tracking something like that down
G
8 months later
#7 8 years ago
Thanks for the heads-up on this!
#8 8 years ago
Great post, will take a peek at mine, Thanks!!
#9 8 years ago
Had that exact problem at the spring pinfest. I switch out some lights before the show and it kept blowing fuses. Luckily I found it minutes before the show started, but I was sweating it out pretty good.
Great POST!
#10 8 years ago
Quoted from Pin_Crazed:
+1
#11 8 years ago
Yup. My GI blew on my first WH20, sure enough when I saw the sparks fly while lifting the playfield it came from that area.
#12 8 years ago
Will do NoVa.
Muchas gracias.
#13 8 years ago
Thanks for the tip,I just massaged the area with my Dremel tool and then wrapped the light socket with electrical tape.
#14 8 years ago
I make a point of never pulling out the playfield while the game is on. If I need to check things, I'll turn it off while I pull up the playfield and then turn it back on.
$ 999.00
Sacramento, CA
$ 75.00
Whitewater pinball mods
