Quoted from Shenanigander:Thanks I will check it out!
No mods. Using slow blow. I wonder what on the playfield is using the 12v line that could cause it? Maybe the up/down target bank?
I think the slot motors use 12v as well as all the opto power. Keep in mind that the stock fused are rated amps at 250v. This is not the same if the fuses are rated at 120v. This could explain why your fuses are blowing intermittently if the new fuses are 120v fuses.
According to Ohm's law a 4a fuse rated at 250v should allow 1000 watts of power through but a 4a fuse rated at 120v will only allow 480 watts of power through. I'm not an electrical engineer so there may be other factors. I remember once having an intermittent fuse blow problem like this and it stopped when I stopped using the 120v fuse to replace the 250v fuses at the same rating. Perhaps on slow blow fuses, the v rating actually matters.
