(Topic ID: 256714)
Cheap Squeak blowing F3 on FBC
By Mr_Positive
5 months ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 5 months ago by barakandl
#1 5 months ago
So the Cheap Squeak board is popping the 4A fuse on my Fireball Classic. This is a bummer because the sound package is one of the best parts of this game.
The problem is definitely on the sound board because when I disconnect the board and replace the fuse, the game plays fine (without sound, of course). I replaced the 4A fuse with a 5A fuse, because that's what I had, and a number of the components start to smoke, but the fuse won't blow. Interesting data point, but I don't recommend it.
I have replaced a number of the caps (C4, C24, C29, C30), diodes (D6, D7, D8) and U9 transistor, but no luck yet. Still pops the fuse.
I see on another thread here, for Spy Hunter, that the 6803 was ultimately replaced as a part of the fix.
Can anyone offer any advice here. Will this do it or am I going down the wrong path.
#2 5 months ago
Take a look at the tantalum caps, C10, C17, C22. These often fail and short out the 12 volt rail.
#3 5 months ago
Will do. Thank you.
#4 5 months ago
The tantalum capacitors across the unregulated 12v are pretty much always bad on this board. The unreg 12v swings too close to the 25v rating of the tantalums. The 12v is also not current limited besides a 4a fuse which you are lucky is blowing instead of the tantalum itself exploding into a fireball.
Use 10uF 35v+ electrolytic caps as a replacement.
Displays
PinballSolutions.eu
$ 49.99
PinballElectronics.com
1,000
West Plains, MO
$ 19.99
$ 119.95
Allteksystems
€ 3.95
Multigame
Third Coast Pinball
