Ok, I'm pretty sure that my Spy Hunter Cheap Squeak is shorting and blowing the F3 4amp fuse.
I just removed the D6 Diode as it looked burned. Left that diode off the board but still the fuse blows.
I checked the continuity of the diode pin points to the TP3 ground and got a reading. (Board disconnected)
See photo.
So now if that means a bad capacitor, where do I start? The caps visually all look good.
Do I just start desoldering the caps one by one and see if the fuse blows?
My other thought is to use test clips to the incoming J1 connector until the fuse blows.
