(Topic ID: 196809)
Chattering slingshots driving me nuts!
By phillyfan64
6 years ago
#1 6 years ago
I know this has been covered before but I cannot for the life of me get the machine gunning slingshots on my Mata Hari to stop. I have adjusted them to no end. They leaf switches are new, new rubber. I cut the capacitors off. Still chattering. I put new caps back on because this machine misses way too many points without them. It doesn't do it all the time but it's enough to be a problem. it happens at least 2 or 3 times a game. I've tried all the advice here on other threads to adjust them. Front blade tight against the rubber. Front blade resting against the rubber. Front blade away from the rubber. I've tried all the different types of adjustments. Could something else be causing this? The contacts don't even look that close. Thank you.
#2 6 years ago
I'd go over the fiberboard spacers between the leaf blades. Clean with lacquer thinner, and sand off the top part. To be sure flux or metal shavings aren't making continuity across the fiberboard spacers.
#3 6 years ago
Quoted from LTG:
I've just finished rebuilding the slingshots because I thought they were a little sloppy. I had another thread posted here. I will look them over carefully. Let me ask you this. The leaf switches are new. The blade stiffeners are straight, not kinked like the old style. Would it help to put a bend or kink in those blade stiffeners?
#4 6 years ago
That looks like a Bally. Did you clip the orange capacitor disc off the switch? If not, do that.
I'm pretty sure those switches are open enough lol. You could drive a truck between those blades.
#5 6 years ago
I have similar issues after restoring my Black Knight too. I have also tweaked the switches many different ways. Oddly my old slingshots worked great. So I will be watching closely on what you come up with OP.
#6 6 years ago
Quoted from phillyfan64:
Not for what is going on here.
#7 6 years ago
I cut the caps off even though they were not old. I had put them on months ago. I put brand new .047 uf 50 volt caps that I bought from Ed at GPE. They were still chattering without them. This game needs caps. It missing too many points without them.
#8 6 years ago
Quoted from LTG:
When you say sand the top part do you mean around the outside edges of the spacers?
#9 6 years ago
Did you clean the new points with a stiff white business card?
I had to do that with my flipper switch on TSPP.
They put a light film or oil in manufacturing sometimes to protect them until it gets to the user.
#10 6 years ago
Are those gold contacts?
Shouldn't they be silver on this era game? Those solenoids aren't CPU controlled.
#11 6 years ago
Quoted from CrazyLevi:
All solenoids on an SS bally (or williams..) are CPU controlled.
#12 6 years ago
Around and between the blades, yes.
#13 6 years ago
I don't think they are gold contacts. I got them from Marco. Part # 1A-120. I did not clean them but I will now. I checked for continuity between the blades. There's no short. The diodes are also new. 1N4004. They test ok.
#14 6 years ago
I take it back. They do look like they are gold contacts.
#15 6 years ago
I got my left flipper repl. leaf switch from Marco too and had to clean the contacts as I stated before with a white business card. I was scratching my head why they weren't working when they looked so good. Not one issue since swiping the card thru them several times.
#16 6 years ago
Quoted from CUJO:
I did clean them with a plain white business card with no change so far but I will clean them again.
This is very frustrating. I should have just left them alone. I was just trying to make them a little more powerful. I changed the leaf switches, plungers, links, sleeves, rubbers, and even the pivoting arms. The only thing I didn't change was the coils. No change in power at all.
#17 6 years ago
What size rubbers did you fit on the slingshots? (manual says they should be 2.5")
If they're oversize/loose they'll reverb back onto the switches too easily and become another cause of machine gunning.
Pull one of the rubbers back with a finger to make the rubber tighter and see if it makes any difference.
#18 6 years ago
Quoted from Quench:
They are 2.5". Brand new from Marco. I will mess with it tonight.
#19 6 years ago
Take the sling rubber off and poke the switch with the end of a pencil eraser. See if you can duplicate the coil chatter doing this.
This will eliminate the rubber causing the bounce.
#20 6 years ago
Quoted from Quench:
I tried this tonight. The problem stopped completely.
Quoted from CUJO:
I also tried this tonight. The problem stopped completely.
I adjusted the front blades tighter to the rubber. That seems to have helped. It's not perfect but it's noticeably better. I will keep at it.
I haven't had a chance to take it apart and sand between the blades as LTG suggested. I will do that this weekend.
One casualty in playing the game without the glass. I broke a big plastic at the top of the playfield. Anyone that owns this game knows that the ball tends to jump and smack the glass at the top of the playfield. Not sure if the glass being off caused it but it sure didn't help.
#21 6 years ago
You are right. That does take a beating. Ball launches off kickout saucer and smack!! Glad you got her fixed.
#22 6 years ago
Maybe the rubbers you got are too soft. They should fit rather tightly.
Pity about the plastic. If you want to repair it, might be worth giving this stuff a try:
https://pinside.com/pinball/forum/topic/best-solvent-to-repair-pinball-ramps-and-plasticsend-of-story
#23 6 years ago
Thanks for the info. I might have a lead on a replacement plastic. If not I'll look into repairing it.
#24 6 years ago
The chattering sling shot issue has been resolved by making sure the front blade was tight to the rubber, the back blade was opened up just a tiny bit more. And also, it's very important to have the blade stiffener tight against the rear blade. That keeps it from bouncing. They may not be quite as sensitive as I would like, but I'll take the trade off. Thanks everyone.
3,500
Pittsburgh, PA
$ 29.00
RoyGBev Pinball
Troxel Repair
$ 12.00
$ 119.95
Allteksystems
1,450 (OBO)
Fredericksburg, VA
$ 69.00
Pinball Pimp
$ 29.00
RoyGBev Pinball
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 179.00
Pinball Pimp
$ 48.00
$ 18.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/chattering-slingshots-driving-me-nuts and we tried optimising it for printing. Some page elements may have been deliberately hidden.
