Hello, anyone know how to fix the display errors shown i picture?
Checked all cables and tried to change displays but the problem remains the same!?
/ Martin
/ Martin
i had a problem with my display lights flickering ,then the game started not to boot up so i changed the orange cap on the bottom cabinet 6800uf 25v and re flowed solder on j3 pins on the power supply no more problems with displays all good
Quoted from NerfHerder:Hello, anyone know how to fix the display errors shown i picture?
/ Martin
As I stated in the other thread, since it's the same segment on players one and two but not on players three and four, I think you have a connection/trace issue on connector A1-J2. Pull the connector, check the traces, check your pins-you might need to repin.
It's not the displays.
Take a "special care" about MPU connector J2 pin 4, ("coroded" board, broken connector pin)
If "everything is OK", replace Z16 on MPU board
WARNING.... do that - ONLY if you have decent soldering skills !!!!
Greetings from Croatia
Quoted from NerfHerder:.and it is the same problem in the two small displays at the bottom I forgot to say.
That is... !
This page was printed from https://pinside.com/pinball/forum/topic/charlies-angels-display-problem-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
