I have changed a lot of flipper buttons but it's always been a pain. Does anyone have a trick to getting that nut off the back of the flipper button?
Needle nose pliers on the inside lip of the nut and then with both hands apply force outward and turn.
I have tried the needle nose, perhaps I need smaller ones. On all my other machines I was able to do it but on the new Stern cabinets it seems to have it sunk a bit more into the wood.
Buy a socket? That's what I did. It's way stronger than needed, but makes the job quick and easy.
Don C.
I saw this early today and couldn't shake the idea of coming up with a tool, so designed a dual purpose tool for removing and tightening flipper button nuts. It clears the flipper button shaft and locates on the inside of the nut so doesn't matter about the lack of clearance on the outside of the nut. It is hollow enough to suit the short and long shafted flipper / arcade buttons.
The other advantage of this tool is that it is also a second option handle for my stainless IDC wire insertion tool
https://www.shapeways.com/marketplace?type=product&q=swinksidc
Quoted from swinks:also a second option handle for my stainless IDC wire insertion tool
.100 tool please.
Quoted from GRUMPY:.100 tool please.
yes, thanks for the reminder of making the other end of the wire inserter a 0.100 - I will get on to this
Quoted from swinks:yes, thanks for the reminder of making the other end of the wire inserter a 0.100 - I will get on to this
Believe it or not, try to spin it off just by using your hand. Last several sets of flipper buttons on newer Stern games I replaced just by turning that nut with my fingers. That nut really isn't on that tight.
I designed a second wire insertion piece that is double ended with the proven 0.156 at one end and the smaller 0.100 at the other. I measured off a new non used pinball life 0.100 tool and this piece will fit both handles.
Quoted from swinks:I designed a second wire insertion piece that is double ended with the proven 0.156 at one end and the smaller 0.100 at the other.
Very clever, thank you swinks!!!
Tornado Terry’s. ^^^^ He used to give them with a purchase of buttons. 100% Happ products. I got one years ago when I did an order for arcade buttons.
Ray on GRC's Youtube series 'Ray's Tech Tips' (required viewing) recommends a set of duckbill pliers to grab one flange instead of trying to span the whole nut.
https://www.amazon.com/dp/B01HYI9QCS/ref=asc_df_B01HYI9QCS5406721/
Quoted from DngrWillRobinson:Where did you get it?
A bunch of places sell them. Just search for arcade push button wrench tool
Quoted from ForceFlow:A bunch of places sell them. Just search for arcade push button wrench tool
Thank you.
Quoted from pinballinreno:Where do I get the little white tips for my flipper buttons. [quoted image][quoted image]
Same question! Couldn't find an answer, does anyone know? Mine is broken on one side and makes the flipper stick..
IMG_5476 (resized).JPGWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/changing-out-flipper-buttons and we tried optimising it for printing. Some page elements may have been deliberately hidden.
