(Topic ID: 128488)
Changing from 220 to 110
By Jargus
  • 12 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by Jargus
#1 4 years ago
I'm thinking about getting a TAF that started life as a 110 machine and was later turned into 220. How hard is it to change it back?
Thanks,
Jeremy
#2 4 years ago
http://www.flippers.be/basics/101_wpc_country_settings.html CPU settings.
Your manual should have the things you need to change on the connector plugged in on top of the on/off switch box.
LTG : )™
#4 4 years ago
I'm getting ready to do a few of these myself, sounds simple enough. Can anyone explain how the machine compensates for the difference in hertz?
#5 4 years ago
The seller says that someone removed the "main filter when doing the original conversion." Does that change the answer in any way?
#6 4 years ago
Quoted from Jargus:
Maybe. If he's referring to the line filter, you'll need to source and install a replacement. It will be located inside the metal box, just inside the coin door.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
#7 4 years ago
Quoted from ozuba:
Nothing needs to be done to accommodate this.
#8 4 years ago
Actually, looking at the pictures now, I can see the whole metal box was removed, which is unfortunate but that's still manageable I think. Just need to find the replacement.
#9 4 years ago
Quoted from ChrisHibler:
Hey Chris, yeah I know, the tinkerer in me just wonders why.
#10 4 years ago
Quoted from ozuba:
I wish I could tell you, but I don't think it will make a difference at all.
The only thing in the game that truly operates from AC is the GI dimming function (via the 4 quadrant Triacs). And the human eye and the "persistence" of the lamps make the difference imperceptible.
#11 4 years ago
Sorry to keep hijacking this thread - converted 3 pins no problem today, have 2 more WPC's to do in the morning. I have a non-WPC (EATPM - Sys 11-B), to which I don't have good references for conversion. Can someone please point me to what would need to convert this game back to 110v? I'm looking in the manual right now & not seeing what I think I should be seeing.
#12 4 years ago
No worries. If I actually buy the TAF, I'll rehijack it or start another one.
Right now it's only theoretical for me, though it sounds like I wouldn't have as easy a time of it since the stock factory stuff is missing in favor of some different hardware.
$ 14.95
$ 65.00
Milford, CT
