My champion pub when the boxer turns around and his right arm will catch the corner of the green ramp when it swings. should The right and left arms be the same height, or should his right arm be a little higher up?
I had a problem that when the ball went slowly around the boxer from right to left, it got stuck under the left hand. I solved the problem by removing the arm, heating it up with a heat gun, bending it slightly, then sticking it in cold water to retain the shape. Not the same problem as you, but you could do the same so the arm clears the ramp.
Quoted from mcclad:I had a problem that when the ball went slowly around the boxer from right to left, it got stuck under the left hand. I solved the problem by removing the arm, heating it up with a heat gun, bending it slightly, then sticking it in cold water to retain the shape. Not the same problem as you, but you could do the same so the arm clears the ramp.
Sounds like it would solves it!
This page was printed from https://pinside.com/pinball/forum/topic/champion-pub-right-arm-hits-the-green-ramp-when-it-swings and we tried optimising it for printing. Some page elements may have been deliberately hidden.
