(Topic ID: 340669)
Champion Pub - Flipper Issue - Sticks Up [Resolved]
By CelticKnot
11 months ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 11 months ago by CelticKnot
#1 11 months ago
Hello pinsiders. I acquired a Champion Pub about 2 years ago and it's been sitting around waiting for me to get to repairing the left flipper, which sticks in the up position when a game starts. Open the coin door (i.e., disengage the high power interlock) or end a game and the flipper returns to the down position. Any suggestions on what to look for? What other information can I provide to help you help me?
Thank you!
#2 11 months ago
If it goes up when the game is turned on bad transistor. If it goes up when you start a game, then check all diodes on the coil, that they are good, and facing the right direction. Then check if the left flipper button opto board works in test, and if the connector or wires are loose on the right flipper button opto board.
#3 11 months ago
Thank you for the reply, LTG. The flipper goes up when you start a game, not when the game is turned on.
Even though I've only owned the game for 2 years, I've known *of* the game for 15. You see, it was in the break room of my old company, and went with the owner of the company when he sold the company and the game stayed at his house for the past 8 or 9 years before I came into possession of it. Looking at the flipper coils they appear to be original, so I don't think the diodes were ever messed with. Tomorrow I'll check the opto boards. From reading other topics here on Pinside it appears I can get to test mode via the setup menu?
Thanks again!
#4 11 months ago
Quoted from CelticKnot:
Thanks again!
I had this exact problem and the issue was my flipper opto board. Replaced that board and all is good again.
#5 11 months ago
Agreed with LTG.
He'll usually suggest swapping the left flipper board with the right.
This does two things:
It tests the suspect part (the left flipper opto flipper board) in the working system (the right flipper opto board system is working).
While you've got it out you can easily clean the optos with a q-tip and some window cleaner.
When you put the opto boards back you'll automatically adjust anything like the interrupts not correctly fitting deep enough in the opto slot to block the opto.
#6 11 months ago
Thanks for all the replies!
Ok, so I made another (unrelated or so I thought) post last night about a mystery part that I found while looking inside the cabinet. From replies from a knowledgeable Pinsider, it turns out that it was a broken white plastic opto board interrupter and I guess the last person that repaired the game just left it in the cabinet after replacing it instead of discarding it.
So I opened the game up again this morning and discovered that same white part on the left flipper -- but the interrupter arm had broken off and was sitting on top of the wiring of the left flipper switch. The right flipper has a black interrupter, which I assume was what had been replaced and the old part just left in the cabinet.
So, I'll be ordering a replacement interrupter today, and I'm hoping that replacing it is all that needs to be done.
#7 11 months ago
Ordered a interrupter and an entire opto board assembly from Planetary a bit ago. If the interrupter resolves my issue, I'll have a spare opto board. I expect it in about a week and will report back. Thanks again for all the help.
PinRetail I'll take your suggestions on cleaning and aligning while I have the one disassembled for repair, and will tune up the good one as well. Gracias!
#8 11 months ago
Thank you again everyone for your replies and help. It did end up being the flipper opto board. (Yes, I see you all nodding knowingly )
Replaced the entire opto board and the left flipper now performs flawlessly.
On to the other issues that need addressing on the machine.
$ 54.95
Gweem's Mods
$ 95.00
Pinball Mod Co.
$ 89.99
$ 37.50
$ 48.00
Lighting - Backbox
Arcade Upkeep
7,000 (Firm)
West Chester, PA
$ 9.95
$ 89.99
