I placed a small 1” piece of 1/4” weather stripping along the right side wall of the scoop about three quarters up, never get any sdtm.
First day with NIB MBr LE...Love the game, but I'm having same issue with the scoop SDTM 98% of the time. I tried all power settings for the R Eject. The only thing that helped was to turn the power to MIN. The eject now sends the ball to the R flipper tip which allows me to save most from SDTM, but it still isn't right...I hate that I have to start to mod a machine right out of the box.
Quoted from soslower:
Try loosening the screws holding the bracket to the playfield and turn as hard as you can while retightening the screws. See if it aims a little better.
I found my scoop needed a slight “twist” towards the left, but it’s not for the faint of heart... I had to lock a pair of vise grips on the scoop and gave it a couple of degrees of leftward twist. That aimed it more towards the left flipper pivot point and it now is a non issue, mine is 100% NOT SDTM, but ranges across the face of the left flipper, from the tip on a soft and slow eject to shooting it back up the inlane on a hard and fast eject (very rare)... I also did the wavy washer add to snug up the coil, and I tried the foam in the inside throat but doing the twist solves this 100%, and I highly recommend it.
