I just bought a CFTBL and flippers were weak and needed some new parts, so I did a repair and replaced all worn out parts.
After the repair the flippers work flawless, but it's like they became too powerful. If you shoot the KISS left loop the ball just bounces back out of the loop most of the time and shooting the left ramp u get an airball jumping out of the ramp 1/3 of the time. I have checked that the correct coils are installed. If i measure the voltage on the coils it read 81V which seems a little bit too high? I tried replacing the fliptronics card from my Dr Who but with the same results, 81V. I don't know if 81V is really a problem but it seems a little bit too high, which might cause the increased flipper strength. I noticed that if i disconnect J102 on the power driver board the flipper coils read 70V. But as soon as i connect it they jump back up to 81V. I've thought about replacing BR3 on the driver board and/or BR1 on the fliptronic board, maybe getting new coils since i guess some previous owner might have removed some copper windings from the coils to make them more powerful but i thought i'd check here before I do anything. Any ideas?
