Hello-
The chase light bulbs in my CFTBL center ramp were changed out to some #86 LED green bulbs by the previous owner. All of the bulbs work fine when in blinking chase mode, but when they light solid green...5 in the ramp and 2 in the bowl do not light. If I do a All Lamp & Flasher test, all of the ramp lights work, except these 5 ramp and 2 bowl lights flicker.
Is this a ghosting issue due to older LED bulbs that need to be replaced or is this a symptom of an issue with the chase light board or power driver board?
Thanks, Rob
