Started a game today and when booting up and starting a game, sounds like game wants to do a check ball sequence by firing solenoids. Game started fine and then when start button was pushed, lower right popper and upper right popper started firing one after another for 5-6 times with ball in shooter lane. Game seemed to play fine, but then when you hit ball into either popper, it didnt register and would only do a ball search again to eject.
Went into test mode and all switches test normal, 2 poppers are registered closed and open when a you block optics. Thought it might be a ball trough issue so checked the trough switches and they seemed fine, but did a small adjustment on the one closest to shooter lane as it didnt look like wire was moving down enough to trigger switch signifying ball was there.
Any other thoughts? electrical ? All wires appear in tact, just seems like a mechanical issue.
