I proto-typed a OPEN sign for CFTBL to connect to the feature light socket under the dome so when the Snackbar is "open" the dome flashes and at certain times would stay lit. But with most of the versions of the Snackbar Mod v3-v7 you can't see this light up well as the dome was removed and covered over with the Snackbar Sign being added. Now with the OPEN sign which has the same font as the Snackbar decal and Snackbar Sign it turn on and glow up like the SnackBar sign.
The led wire still needs some heat shrink over the wires so the glow coming out the back is greatly reduced. But once assembled here, there is no need for you to pull apart but is designed so it can. The sign will come with a wire lead and COMET bulb adaptor so it can be lit when the feature comes on.
I still got to work out the final price (between $130-150 AUD + postage) and finish testing, but send me a message if you are interested. Priority will be given to those that reach out in the order of who reached out when.
Pinside PM
or
Email - [email protected]
Subject - OPEN Sign
UPDATES:
a few people have asked a few things so will share here.
- It will work with any Snackbar Mod
- It will work without a Snackbar Mod and can just be a stand alone mod
- It will plug into the feature light socket under the dome so no pcb's or extra power is required.
