(Topic ID: 219176)
CFTBL - intermittent dead right flipper
By cloudburst
1 year ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by cloudburst
#1 1 year ago
Hi there,
Occasionally since yesterday my CFTBL right flipper is unresponsive. First thing I did today was to clean the optos. However, when it happened again I went straight to the flipper coil tests.
L HOLD works fine
L POWER works fine
R HOLD works fine
R POWER doesn’t work
However, when I exited the tests, it works again for a while!
So I went back into the tests and set it to repeat the R POWER test. Wasn’t working. Then I went back to R HOLD test and repeated that. That then seemed to free up the R POWER test and it worked - but every so often missed firing the flipper and then stopped flipping. Then I was able to get it working again by the exact same method of performing a repeated R HOLD test.
I love my CFTBL - so would really value some help on where I should check next. Many thanks!
CB
#2 1 year ago
Sounds like a loose wire on your solenoid. Check and make sure it's really well soldered to the lug.
#3 1 year ago
Or the diode is broken off the coil, or one of the coil wires broke off of the solder lugs.
#4 1 year ago
Quoted from CadillacMusic:
Thanks cadillacmusic - that’s exactly what it was! Now sorted.
CB
Gweem's Mods
$ 159.99
