My CFTBL Hologram Mod by PinballmikeD stopped booting when I started a game. The Mod has worked perfectly after I installed it many years ago. The insignia TV monitor is displaying a string of error messaged that say could not mount boot FS. I tried power cycling and starting the game but same error message. The raspbery PI is getting power as the top two Red leds on the Led block are solid red and the lowering leds are strobing on and off as the game is in attract mode. I should mention that I have Mikes Power supply mod also that supplies 12VDC to the monitor as well as the Power adapter that provides clean 5 volts to the Raspberry also . I also turned game off, waited 5 minutes, unseated and then reseated both the SD card and the thumb drive. turned game back on but got same error messages on the monitor. I had made a backup copy of the original thumb drive on my PC when I first got the Mod from Mike years ago and I followed the procedure to re-image the SD card using the files and the windows diskmanager software provided on the thumb drive. I purchased a new SD card to put the image on instead of using the original SD card. However , I still get the same error message cannot mount boot error with the new SD card. Note I did change the Boot delay timer in the config file to 4 instead of the default 2 but that did not help. I tried reaching out to mike here on Pinside and thru his older email but I have not received any response. Hoping someone may have experienced a similar problem and or may have some thoughts, suggestions or ideas they might share. Thanks, I do have a picture of the error messages if someone would like to see it.
