(Topic ID: 129853)
CFTBL: Flipper Won't Hold
By lowga41
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by lowga41
#1 4 years ago
Hoping one of the tech whiz's can help with this. The left flipper on our CFTBL suddenly developed problems. It works, but is "jittery" almost vibrating. Also it will not allow you to hold or catch the ball. If you hold down the flipper button, it fires, but then immediately returns to the "down" position.
We're supposed to be hosting a pinball party next weekend, so I really want to get this fixed quickly. Any help appreciated!
Any ideas?
#2 4 years ago
It's likely a broken hold winding, or a bad or broken diode that connects to it. Take a look at the copper winding on the flipper coil, the thinnest one is the hold winding.
#3 4 years ago
I watched one of Clay's repair videos last week where a TZ machine had that weak "jittery" flipper issue and it was a bad optic switch.
edit: it was because the faulty optic switch outputs a weird voltage and confuses the fliptronics board
#4 4 years ago
Throw the game into Test - Switch Edge Test
Hold down the flipper button
Does the switch stay closed stably or does it flutter?
Clean the U-shaped optos under the flipper button with a q-tip and alcohol
Same? Better?
Swap the flipper opto boards R to L and vice versa
Does the problem follow the board (swaps to other flipper)?
RussM
#5 4 years ago
And that's why pinball is the best hobby in the world. Advice turned out to be solid. Switch test revealed abnormal behavior. Swapped flipper opto board to other side, and problem did not travel.
Inspected flipper coil closely and wiggled some things. Broken diode revealed itself. Out came the soldering iron, new diode went in. Problem solved. Did some preventive maintenance while I had the "hood up"...everything looks great for the party!
Thanks guys! You all rock!
$ 109.99
$ 28.00
$ 399.95
$ 74.00
Id Rather Play Pinball
