hi folks,
Creature from the black lagoon............
i wanted to look at the opto on the right flipper as it didn't feel to be playing
quite right with quick flipper taps. Also - i may have been imagining it -
but it seemed to flip momentarily with no pressure.
i noticed that the opto interrupter on the right was way higher out of the opto
than the left - for no real reason other than the board seems to be slightly closer
to the cabinet.
i took the board off and slightly repositioned it to match the left flipper.
But then....with repeated flips the right flipper stuck up, quite frequently.
So I put the board back as it was (well as close as possible), the interrupter
previously was against the side of the opto - now free i believe.
But it still sticks though not as often. And also i think i'm getting ghost flips
too.
Is this just a case of replacing the opto board? And if so - is the interrupter
going to be ok with the new board?
Thanks in advance.
