Chris Hibler on here does very good work. His handle is ChrisHibler. There are a few other good people here but I haven't used them.
My guess is that one is too far gone to be saved. Grab the ASIC chip out & order a new board from the distributor of your choice. I recommend Arcadeshop or K's arcade. Then put the board up on EBay and see if anyone wants it for parts or project. You can recoup a few bucks from it to offset the new one.
K's out of stock https://ksarcade.net/rottendog-mpu-for-wpc-89-base-unit-mpu089-replaces-wpc-a-12742.html
Arcade shop looks like they have them. $149 if you move the ASIC & ROM's over http://www.arcadeshop.com/parts.htm#Pinball%20Parts
Ick!
I'm afraid that one's dead.
It would need at least 10 ICs and 50 resistors/diodes/caps replaced in addition to cleaning up the traces. I can see that the corrosion has invaded under the solder mask to the left of U17. And, "it's always worse than it looks like in the picture".
Butch2099 is right. Pick up a replacement.
Make sure that the switch matrix connector pins and housings that plug into the bottom of the board haven't been damaged.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact/
Quoted from ChrisHibler:Ick!
U beat me to it by a few seconds lol
Thanks for all the replies...you've all confirmed my suspicions. Are Rottendog replacements any good? I can recall reading somewhere that they could be 'buggy'? Don't know if that's fact or fiction. Thanks again....
I would personally avoid Rottendog. They generally introduce their own world of issues. Find a used working or repaired original CPU board. This guy has a couple for sale from a Hurricane and Popeye. His stuff is guaranteed to work and I have bought from him a few times with zero problems. Will most likely work, but double check your part number with the ones in those game manuals.
https://pinside.com/pinball/forum/topic/selling-pinball-parts
Quoted from CubeSnake:Thanks for all the replies...you've all confirmed my suspicions. Are Rottendog replacements any good? I can recall reading somewhere that they could be 'buggy'? Don't know if that's fact or fiction. Thanks again....
I have had several rottendog boards. I believe I have replaced one transistor and I think that one was my fault. Jim guarantees his boards too. He posts his cell number on the website. If you have a problem with it just call him.
This page was printed from https://pinside.com/pinball/forum/topic/cftbl-can-this-be-fixed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
