(Topic ID: 239063)
CFTBL blows F116
By GameVault
1 year ago
  • 22 posts
  • 7 Pinsiders participating
  • Latest reply 1 year ago by JayDee
#1 1 year ago
I borrowed my technicians driver board and the same thing happened. But we realized the 2 motors on creature were stuck. So we disconnected them.
Still blew fuse.
So we disconnected the hologram bulb/light and it stopped blowing fuse on both driver boards as of now.
We also disconnected the color dmd I had running to rule that out.
Don't know what to look for next.
#2 1 year ago
I have a client that has several mods and a color dmd etc on thus title. It seems this particular game has the 12vdc maxed out and add ons will blow the fuse. He has the same issue esp when the hologram runs.
If a short on the holgram lamp socket is ruled out possibly look at powering the color dmd with its own supply.
#3 1 year ago
Had same issue with mine once I put color dmd in. Turns out the 12V circuit is notoriously close to overload on these machines and the new dmd pushes it to the limit. Change the hologram bulb to a LED. It fixed my issue and never blew a fuse since. Good luck
#4 1 year ago
This is what I used
#5 1 year ago
Quoted from JayDee:
This is what I used
I am ordering now.
Did you get cool or warm?
Also I mentioned above I disconnected the color DMD and still the hologram bulb blew the fuse..
I still want to get the LED which is an excellent idea.
#6 1 year ago
Quoted from GameVault:
I am ordering now.
I actually bought one of each because I’m OCD and ended up using the cool white because it seemed slightly brighter. I’m not sure what to say about the fuse blowing with dmd disconnected. My issue was the fuse would blow when the hologram ran with the color dmd. It didn’t blow with the original dmd though.
#7 1 year ago
Just re-read your post, did you disconnect the bulb at the harness connector or just pull the bulb out? Maybe the issue is the bulb itself and not the whole socket assembly
#8 1 year ago
do you have any other mods on the game that pull power as that is one of the common causes like snackbar mod v1, speaker panel mod, mini tv or car mods?
#9 1 year ago
Quoted from JayDee:
disconnected harness only.
So maybe it is the bulb.
#10 1 year ago
Quoted from swinks:
I do not have any other mods.
#11 1 year ago
Pull it and keep dmd hooked up and see what happens. Need to start somewhere and systematically work your way back to the power supply so to speak
#12 1 year ago
lift your playfield and check the wiring of the soleniod of the VUK as that can catch on the shooter rod and pull off and create a short if touching something else.
#13 1 year ago
Quoted from pinballplusMN:
How is this dome?
#15 1 year ago
Quoted from swinks:
I will check in morning
#16 1 year ago
Quoted from transprtr4u:
How is this dome?
Done. I use pc 12v power supplies. Anout 20-30 from Amazon
#18 1 year ago
Seem it blows with the bulb connected.
If I remove the bulb, it does not blow the fuse.
#19 1 year ago
That’s a good sign I suppose. Maybe all you need is the led bulb like I did.
#20 1 year ago
I was having the same problem with mine and what I did that seemed to work was 1: change to led bulb and 2: decrease the brightness on the color dmd
It might be worth trying
#21 1 year ago
Quoted from JayDee:
New bulb fixed it.
No more fuse blowing.
#22 1 year ago
New bulb fixed it.
Awesome! Glad to hear that!
$ 235.00
RS Technologies
