(Topic ID: 82546)
CFTBL blowing fuse 115
By fiberdude120
5 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by vilant
#1 5 years ago
Just finished reassembly of the pop bumpers and reinstall the ramps and the fuse is now blowing. It is fuse 115 the manual says its the switch matrix. All worked great before hand and now when I power it up the display reads (check fuse 114 and 115). and thats as far as it will let me go. Any ideas would be great thank you.
#2 5 years ago
No ideas?
#3 5 years ago
Usually one or both blowing is indicating a bridge rectifier on your power driver board has went bad and needs replaced. I had this happen one time after rebuilding the flippers on one of my WPC games. search fuse 114 and 115 on pinside, there is a quite a few topics on it and they have the links to the steps on how to diagnose. Hope this helps.
#4 5 years ago
It does not blow fuse 114 it just tells you to check them. It only blows 115. I will check the article to see what info I can get thanks.
#6 5 years ago
I know when I reassembled mine after a shop job, I noticed a few switches incredibly close to metal parts. Make sure a diode hasn't bent over and touched these parts (the metal leads of the diode). 1 that comes to mind is the up ramp switch. I'm sure there are others but can't remember where. If you don't see it visually, time to pull out a DMM and start checking continuity to ground.
$ 129.00
LED OCD
$ 159.99
$ 229.99
$ 29.99
Full Tilt Pinball LEDs
Gweem's Mods
$ 69.99
$ 9.99
$ 279.95
$ 279.95
$ 49.99
€ 95.00
FlipperLED
Baltimore, MD
$ 229.99
$ 109.99
$ 29.99
$ 279.95
Fullerton, CA
$ 999.00
