Hi pinsiders
"Call for Help" --- in another topic we try to fix the mentioned feature (Spirit of 76). I am close to believe in Voodoo-Magic or little gremlins at work --- or maybe we have a behavior "strange to us" --- but normal / happens to be that way in a fully running such pin (?).
Do You have an schematics of Pioneer ? Please look-up the "area schematics 19-E,F,G,H,I" --- does this looks exactly like my JPG, E-Relay and O-Relay and the wiring and switches ? Please write about and/or show this area.
Nick (in the other post) writes about "O-Relay pulls-in - let-go --- pulls-in - let-go etc. EXACTLY five times on a Motor-Turn, FIVE PULSES --- BUT: The O-Relay does NOT pull-in and stay pulled. Strange to me --- is this a "normal behaviour - ghost to me" or a fault ? When You have an running Spirit of 76 / Pioneer: Please look at the O-Relay at the time the Bonus is stepped down when a ball is lost --- does YOUR pin shows "FIVE PULSES on the O-Relay" ? - or does the O-Relay not actuate while the Bonus is counted down - then pulling-in and stay pulling for "to kick-over the ball to the shooter alley ? Please write about.
Do You have an SteveFury-Testlight (made of two 12Volt car-lamps) ? See "encircled Yellow" in my JPG --- when You mount Your Testlight, connecting to the Coil on O-Relay --- do You get short flashes of light ? --- or do You have "either dark - or shining steady (as the O-Relay is steady pulling)" ?
The "other topic" is this: https://pinside.com/pinball/forum/topic/gottlieb-spirit-of-76-bonus-countdown --- some 26 posts --- some testing done - no success so far - please write "here" or join "the other topic". Greetings Rolf
P.S. I believe this happens in an running pin (NO pulsing on/of the O-Relay): A ball is lost and enters the Outhole - some Bonus are on the Bonus-Counter. Along my green lines "Initial Current flows and makes the (6) E-Bonus-Unit-Score-Relay pull-in. It lets the Motor do a turn, also actuates all its switches - so "Self-Hold-Circuitry is established along my orange line". This will be cut by the (late) opening of "my switch 8" - the E-Relay let go.
IF (if, if) there are some more Bonus to be counted down: "The written above" is done a second time.
IF (if, if) there are no more Bonus: Along "my lightblue wiring" the O-Relay gets Initial-Current, pulls-in, stays pulling (Self-Hold-Circuitry is the darkblue wiring) - makes the motor run and finally (closing Score-Motor-Switch-4C): Kicks the Ball over to the shooter alley.
