Hi gang, finishing a restoration on a CP, I need a close up pic of a jones plug feature setting. Here's a partial pic from the IPDB, I can almost read what it says but not quite. The one one the left. Somebody get me a pic?
ken
Hi pinhead52 +
You have identified the No. Match Feature Adj. Jack. The other Adj. Jack (picture, post-1) probably is the one shown at schema-G-12: "Extra-Chute-Adj. Plug": 5, 4, 3, 2 (empty socket) replays per coin. At F-17 I see in the schema a single plug and dashed wiring connecting "AS"-Relay: "2 coins-per-play-Relay, only in games made for 2 coins per play".
Another Adj. Feature is of course: "High score-Adj, Limits to gain replays by the counter".
At schema-F/G-10/11 is shown "Advance Special when lit Adjustment" - "Liberal with connection" "Conservative empty socket" - TWO plugs - 4 sockets - either both plugs have connection or none has. Can You tell me where this Adj. Plug is mounted in the pin (underneathside of playfield near the player ? (My Wms Space Mission has some Adj.-Plugs mounted there)
At schema-F-5/6/7 is shown: 3-5 Adj. Plug - 6 plugs to change position - Where is this located ? (Backbox ?)
Greetings Rolf
Yes the Liberal/Conservative plug is under the pf, pretty near the left flipper switch. You can see it in this pic http://www.ipdb.org/showpic.pl?id=481&picno=22288 and the 3-5 ball is left side all the way to the top of the pf
This page was printed from https://pinside.com/pinball/forum/topic/central-park-feature-label and we tried optimising it for printing. Some page elements may have been deliberately hidden.
