Hello fellow Pinside members,
I am having problems with my Centigrade 37. The lights do not alternate as they should. I have given all the info I thought could help as briefly as I can. I have also made a video showing the odd behavior and the relays mentioned below. Any help is much appreciated - and it’s o.k. to explain things to me like I’m a child. =)
Here is a video showing the issues and relays mentioned below.
Thanks very much.
The Problem
* Centigrade 37 lights not alternating correctly
* Intermittent behavior
* Sometimes they work as expected
* Sometimes lights do not alternate at all
* Sometimes they will flicker - rapidly alternating back and forth several times when they should only alternate once. (See video)
* When in this “rapid flicker mode,” I’ve noticed the A-Relay under the playfield firing off and on (See video)
* Sometimes a gentle rap on the apron, side of the cabinet or engaging a flipper will produce the rapid alternating effect. (See Video)
Things I’ve Noticed
* Noticed that rapid flickering seems to be controlled/influenced by the A-Relay (See Video)
* My “AS-Relay” is labeled “FS”
* The AS (FS?) Relay appeared to be in good shape (copper was clean and wiper moved freely) before cleaning it.
* The contacts on the switch stack in the AS (FS?) Relay appear to show a build-up of matter - the contacts are not flat as I’d expect.
* The Match function works properly.
What I’ve Done About It
* Tried a variety of scenarios to reliable replicate the malfunction and cannot
* Read forums related to this issue
* Reached out privately to a very helpful Pinsider, MIKEO, who shared tips on refurbishing the AS-Relay (Thanks, @mikeo)
* Removed, disassembled, cleaned, reassembled, reinstalled the AS-Relay as indicated in Pinsider @ccotenj thorough guide found here: https://pinside.com/pinball/forum/topic/gtb-as-match-stepper-rebuild-step-by-step
Just Wondering…
* From what I’ve read, the AS-Relay seems responsible for the alternating lights, but the A-Relay under the playfield seems to have a role as well
* The innermost return lane on the left side doesn’t trigger most of the time - no scoring, chime, or activate the alternating lights. Under normal operating conditions, I’d expect this switch to alternate the lights when the ball rolls over it.
* Could the issue be related to this malfunctioning return lane? Perhaps a malfunction in the switch on the return lane is sending (or not sending) correct signals to trigger the A-Relay properly?
My Mechanical Background
* I can identify main parts of EM pinball machines.
* I can successfully make a halfway-decent solder connection.
* I can operate my toaster without burning my bread 98% of the time.
* I am willing and eager to learn.
This is my first time posting on a Forum. Please forgive me if I’ve not followed the correct protocol - I’m learning all kinds of new things! Thanks again.
