I've run into some odd voltages on my Centaur machine and, based on my rudimentary troubleshooting, it seems there's a problem with the transformer and/or its wiring.
Using both the original -54 and a brand-new replacement -54 from Anarchy, I get some really weird voltages at all TPs. All fuses are good on both boards and both boards previously would get me to GI lighting. I would appreciate direction, as many of you know way more than I do or probably ever will. Below are the various values I get with just J6 connected.
BEFORE replacing the J6 connector and terminal pins:
OLD Board | NEW Board
TP1: 0.1 VDC | TP1: 0.1 VDC
TP2: 0-2.1 VDC | TP2: 2.1 VDC
TP3: 37 VDC | TP3: 25 VDC
TP4: 70 VAC | TP4: 38-65.5 VAC
TP5: 0.0 VDC | TP5: 0.0 VDC
AFTER replacing the J6 connector and terminal pins:
NEW Board
TP1: 0.1 VDC
TP2: 12 VDC
TP3: 20.7 VDC
TP4: 92-153 VAC*
TP5: 0.0 VDC
*for TP4, I got readings of 92, 120, and 153 VAC just by bending the wiring harness this way or that.
Line voltage is 125.8 VAC (high, but within 5% tolerance), measured both at the wall and at the connector ahead of the fuse.
Based on those TP4 numbers, I'm guessing there are some cracked solders on the transformer itself. I haven't (yet) done anything with the transformer, as I'm unsure it's worth my digging around inside. Should I just go shop around for one instead? I have no problem checking this and that or doing some soldering and I can pick my way through a schematic. If someone here has a solution or a direction to lead me, I'm more than thankful.
Cheers!
