My centaur MPU (alltek) fails to boot if any switches in a certain return row of the matrix are active on power up. Repeatable when a different alltek MPU is swapped in, so the issue is under the playfield and not the MPU. A couple of these switches are on drop targets, and I'd rather fix the issue than remove the glass to manually reset drops before turning it on.
Everything *looks* ok at the switches. And I've tested all the switch diodes in circuit and they seem good.
A few of the switches have ceramic disc capacitors, my multimeter does not do capacitance. Can a failed disc capacitor on a switch cause something like MPU boot fail? If yes, then I'll just order some and replace to see if that does the trick. If no, is there something else I should be considering?
