I have had this problem since I got the machine going a few weeks ago. Once the 1st inline target is hit every time the left flipper is pressed it will score 5000 points and will light the Right outlane (worth 5000). I have been testing and replacing diodes like a mad man but to no avail.
The left flipper (lane change) switch had a diode which I believe was in backwards however aside from the switch problem described above it seemed to work correctly. If I put it in the same way as every other diode on the game it would register as a stuck switch. If removed it works normally aside from my initial problem. Should there even be a diode on this switch?
I have changed diodes at the flippers, 1st and 2nd drop, right outlane plus a few others. All oriented correctly.
Machine has new Altek boards.
Can anyone more experienced with the switch matrix point me in the right direction.
Cheers
