Symptom: When a ball is served to the shooter lane or either flipper is triggered I get 10 points. The points aren't as annoying as the sound it makes every time.
Tried:
Switch matrix test shows switch 34 is closed. This is the 10 point switch to the right of the right pop bumper. Just below the green target.
The switch does not test closed. I unwired it and it still reports closed.
I temporarily swapped in an alltek mpu and it has the same issue. I also have a rottendog SDB installed.
I don't fully understand the switch matrix yet but looking at the diagram it looks like I should check the diodes on: both flipper buttons, left side rollover, and the right slingshot. (not sure the direction the matrix scans so I'll check them all)
Am I on the right track?
