Once out of about every 20 - 25 times the bank of targets go down, they fail to reset. It is usually reset on the next ball. FYI...The previous owner replaced the targets and springs. What can I do to eliminate this?
Thanks,
Dave
Thanks,
Dave
Dave. Each drop target has a leaf switch behind it that closes when the drop target falls, telling the game it was hit. If the switch is flaky or not making good contact, ie dirty or out of adjustment, the game won't know it's down and therefore won't reset until the next ball. Check all the switches in that target bank to make sure they are doing their job. That would be the first thing I would try.
I see you have a ton of games and lots of years here, so you've likely checked this obvious stuff already eh?
The switches are all set properly.
Now the drop target reset does not even take place in the solenoid test mode (happened only once) or upon next ball.
The resistance on each coil is good (21.5). Any ideas on where to go next?
Thanks,
Dave
Try resoldering the connector on the Solenoid Driver board and check the pin on the connector for that bank of targets.
Quoted from DnDPins:The switches are all set properly.
I think Shockme is correct. You have to clean the leaf switch contacts. I use 2000 grit sandpaper for this and it works well. Place
between both contacts for each target when the targets are down and swipe a few times. Should clear it up.
Quoted from Barakawins1:I think Shockme is correct. You have to clean the leaf switch contacts. I use 2000 grit sandpaper for this and it works well. Place
Thanks for this input however doesn't it seem that the fact that it does not reset in test mode or upon next ball indicate something other than the switches? It seems logical to me that if it were switch related, it would not reset during the ball but would in test or next ball.
You are correct with your logic. No answers here, but if you do clean contacts and they are the gold plated variety, use a fresh dollar bill or a business card that isn't glossy. Is the coil for the reset ok??
This page was printed from https://pinside.com/pinball/forum/topic/centaur-ii-drops-target-sometimes-do-no-reset and we tried optimising it for printing. Some page elements may have been deliberately hidden.
