I suggested (via your PM), to clip the MOV lead close to the solder joint (not next to the component). If you did, it could be resoldered back onto the lug.
That dark spot appears to be some kind of oil or liquid leaking out of the EMI filter. Therefore, I might suspect it as being a problem.
If you change the EMI filter, you might as well install a fresh MOV.
Okay, new approach:
Can you solder/unsolder (like changing a coil)?
Do you have a working ohm meter (DVM)?
If yes to both, you should check across the two spades of your line cord for a short. If you have a ground pin (not sure how things are typically wired overseas), you should check each spade to ground. No shorts should exist. If you find a short, it could be one of three things:
Shorted MOV (already been cut out of circuit).
Shorted EMI filter (never seen one in my 35 years of tech work, only ones that open up circuit. But then, I don't normally work with much equipment connected to 220).
A short in the line cord or plug. Check for crimp marks, if molded plug is replaced, suspect shorted wiring inside. I am not understanding your "replaced plug fuse"? I have never seen a fused plug other than on a string of Christmas lights.
If the cord and plug check out okay, one would unsolder the line cord from the EMI filter and retest for the short - across terminals on the EMI filter, and wires of the cord.
